raresvintea
Hello everyone. I've installed in my car heated seats. I've put in seats a NTC 10K&15K sensor. The potentiometer from dashboard can make a course between 5kOhms at "low" and 2.2kOhms on "max".
I've tried to make a thermostat using a lm741 but the point of stop was really hard to manage, and i've put some swiches, now in the winter. I want to make a better device!
The problems are:
-long wires from sensor to the "control unit'- 3meters
-already installed NTC sensors
-the limmited course of the pot from dashboard.
All i want to make is a device that can handle temeperatures below -15C, to menage voltage fluctuations because of electrical system and hard conditions. The circuit that i've already maked was based on a voltage comparator, that commands a small power transistor and after that a P channel mosfet to minimise looses and to avoid noise from a relay. What i want to make is a circuit that can handle this.
I think that i need to put a voltage stabilizator LM7805 to be sure that all the time i have a constant voltage for voltage reference. And to use a circuit that can handle -20 degres and to be perfect functional... military ones, because i don't want to fail when outside is very cold, because otherwise i will fail
I need to say that i made a small series-parralel resistor circuit to put the value from the ntc sensor in Comparison with the one set onthe potentiometer.
PLEASE come with ideeas and with recomandations. There are some specialized circuit to do this?
The problems are:
