BrentNewland
I've been considering building a controller board for a swamp (evaporative) cooler to interface with any standard programmable thermostat.
I've been having a hard time finding information on what voltages a thermostat works with, but I've been able to determine the basics (I think):
Power feed is 24v A/C from air conditioner
Some thermostats support 2-stage air conditioning (a two stage compressor setup)
--I don't know when the two stages kick on, or if both are active at the same time; I am assuming that the second stage comes on when extra cooling is needed, but it may be for a fancy start-up sequence
A single wire is sent to the air conditioner to turn on "cooling"
A single wire is sent to turn on circulation fans
Power is constant from the signal line when the feature (cooling or fan) is turned on
--According to here
And how a Swamp Cooler controller is wired:
Here is my thought:
Would need to have a 120v a/c to 24v a/c converting circuit (I'm sure I could find one on google)
--Not sure of the amperage needed
24v a/c gets sent on a wire to the digital thermostat
First and Second stage cooling wires and fan wires are run to the controller (near the manual swamp cooler controls)
Fan line is connected to a 120v relay that is connected to the low-speed motor connection
Stage 1 cooling is connected to a 120v relay that is connected to the low speed motor connection and a second relay (in series?) that is connected to the pump connection
Stage 2 cooling is the same as above but with the high-speed connection
That should allow a digital thermostat to control a swamp cooler, I think.
The only areas of concern I have are:
Starting amperage of the motor and pump
--I read the motor can draw between 5 and 15 amps while running, I'm worried starting voltage could be much higher
Type of relay
--I was looking at Solid-State Contactor relays and Latching relays, not sure what the best and most affordable would be
--Also, where I would even find one (are they all really $80+?)
Manual controlling of a hooked-up swamp cooler
--might make circuit more complicated by having 2 24v sources and not being able to have them hooked up to the same relay (since you can't send voltage to the thermostat over the signal line, it might fry it)
Possibly needing to wait a few minutes for the pump to run (and wet the pads) before starting the fan
--Saw a few sites mention time-delay relays
So, does it seem feasible? See any flaws, or have advice? I don't dabble in electronics very much, so forgive any rookie mistakes.
--According to here
Here is my thought:
Type of relay
