ghostman11
i had a very bad accident late last week and have smashed my arm! i overturned a quad bike and after 2 ops have a multitude of plates and screws holding it together, but its looking like i might loes the bottom half of my arm in the long run..........anyway not to dwell too much on the painful, i cant do very much to my projects so i am forced to trawl the net and do some reading, wich brings me to the point of this post (see got there aventualy
) i came accross the following and thought as it had made me smile i would share with you,
its origanaly from the pic list and a guy called by Lawrence Lile, i hope he dosnt mind me posting it here.
The Ten Commandments of C Style
A remedial course for caps criminals
by Lawrence Lile
1. Woe be to those errant scribes who ignore capitalization in the writing of the C program, and a plague of frogs on those who turn off the switch of capitalization.
2. Thou shalt not capitalize statements such as the "if " or the "for " .
3. CONSTANTS shall be shouted to the multitudes in all caps, from every rooftop and steeple, as they are the unchanging firmament and change not through all time, and woe be to those that confuse them with variables.
4. Those Types and Structures which are user defined shall be presented with the first letter capitalized, as they are the high born, lest they be confused with the lesser variables, nor with the shouted CONSTANTS.
5. variables shall be lower case, even as they start a sentence, for they are the low and common peasant workers doing the everyday drudgery of programming work, and must not be confused with the high-born Structures, nor with the ever-stable firmament of CONSTANTS.
6. Brothers have come to blows o'er the use of long variable names, with many favouring the internal capitalization, thus the use of long int numberOfPeopleInHell; whereas others have countered with heated words that the proper way would be long int number_of_people_in_hell. Woe be to those who use either name, for it is likely not unique in the first six to eight letters, making some compilers gnash their teeth, while the true scope of the number of people in hell would vastly exceed the capacity of the long int, causing the dreaded plague which infecteth, locketh-up and rebooteth all computers from the lowly PIC to the mighty Cray.
7. While much blood has been shed over the issue of the curly brace, and many are the programmers that have argued that opening curly braces should go on their own line, while others have protested with sword-in-hand that they must go on the same line as the statement, and many have come to blows over this, the closing curly brace shall be indented to the same level as the opening function.
8. Thou shalt not comment the obvious. Those rapscallions and heathens who penned the line
i++; // Add one to i
shall be forever banned from the inner circle of C, though their resume grow long and their accomplishments and finished code stretch out before them like a lake of ASCII text. Likewise, any code which is not obvious, or obfuscates and bebothers the user, shall be extensively commented so as to make clear the intent of the programmer.
9. Thou shalt comment the author, date, and revision of each C program, and lo, other comments shall be brief, descriptive, to the point, yet clear as the purest mountain spring water in their explanation and clarification of the code. Each function shall have as its companion a description of its function, its inputs and outputs, as each dog has its day and each actor his moment on the stage. Thou shalt document the purpose of each and every I/O pin in an embedded processor, and for each variable, data member or Structure there shall be a comment which shall illuminate and enlighten the reader of the program as to its use.
10. Thou shalt properly indent programs, each subservient function being indented one level more than its master.
by Lawrence Lile
