PG1995
Active Member
Hi
We have a single phase connection. It's 220V. I think it's RMS value so the peak voltage would be around 311V. Two wires are used for this single phase connection (forget the earth wire we don't use it here, we use circuit breaker for every room). I don't know anything about three phase connection. I want to when such a three phase connection is required and what its advantages are as compared to single phase. Please remember that I'm a beginner so please try to explain things using math formulas. I'm after conceptual understanding. Thanks.
RMS value is a kind of 'average' voltage. If RMS is 220V then that means it would deliver the same amount of power as a 220V DC supply. Correct?
The following picture shows that Phase 2's peak is 120° out of phase from the Phase 1's and Phase 2's.
All the three phases (three voltage waves) have the same peak voltage which means same RMS value. If the peak voltage for all the phases is 311V then the RMS would be 220V. Correct? Then, doesn't it look as if we have three 220V DC supplies in parallel? Please tell me.
How many wires are used for three phase connection ignoring the ground wire?
I have been told that three phase connection is used for power hungry devices. If we have three batteries in parallel then they have the capacity to deliver more power than a single battery.
Please guide me with the above stuff. Thanks a lot for your help and your time.
Regards
PG
PS: Are you thinking why don't we have the ground wire? A circuit breaker is used in every room. So, if someone accidently touches the wires/some electric device create a short circuit the circuit breaker will shut off the current by tripping off. Why don't they use the ground wire? I believe they do it to save money. The electric company would need only two wires instead of three by not using the ground!
Regards
PG
