lord loh.
I am using 18F452
I tried to experiment with timer0... I set a prescale factor and was generating interrupts. For each interrupt, I was incrementing a variable whih was in the watch.
However when I set precale 1:2 and prescale 1:4, the simulator did not generate any interrupts...
I looked for all possible typo errors etc.. But It just does not make sense. If I just change one bit in the T0CON, >>TOPS0,TOPS1,TOPS2, The programme works...
Has anyone ever faced such a problem...
Please help me out...
MACRO.INC
MAIN.ASM
SUBROUTINE.ASM
MACRO.INC
timer0.enable MACRO
bsf T0CON,TMR0ON ;Sets bit7 of the T0CON register
ENDM
timer0.disable MACRO
bcf T0CON,TMR0ON ;Clears bit7 of the T0CON register
ENDM
;Macro to set timer0 to 8bit / 16bits.
timer0.8Bits MACRO
bsf T0CON,T08BIT ;Sets bit6 of the T0CON register
ENDM
timer0.16Bits MACRO
bcf T0CON,T08BIT ;Clears bit6 of the T0CON register
ENDM
;Macro to select the timer0 clock source
timer0.counter MACRO
bsf T0CON,T0CS ;Sets the bit5 of the T0CON register
ENDM
timer0.timer MACRO
bcf T0CON,T0CS ;Clears the bit5 of the T0CON register
ENDM
;Macro to select the timer0 Clock edge
timer0.pTriggered MACRO
bsf T0CON,T0SE ;Sets the bit4 of the T0CON register
ENDM
timer0.nTriggered MACRO
bcf T0CON,T0SE ;Clears the bit4 of the T0CON register
ENDM
;Macro to set the timer0 prescalers
timer0.prescale1 MACRO
bsf T0CON,PSA ;Sets the bit3 of the T0CON register
ENDM
timer0.prescale2 MACRO ;Prescale 1:2
bcf T0CON,PSA ;Sets the bit3 of the T0CON register
bsf T0CON,T0PS0
bsf T0CON,T0PS1
bcf T0CON,T0PS2
ENDM
timer0.prescale4 MACRO ;Prescale 1:4
bsf T0CON,T0PS0
bcf T0CON,T0PS1
bcf T0CON,T0PS2
ENDM
timer0.prescale8 MACRO ;Prescale 1:8
bcf T0CON,T0PS0
bsf T0CON,T0PS1
bcf T0CON,T0PS2
ENDM
timer0.prescale16 MACRO ;Prescale 1:16
bsf T0CON,T0PS0
bsf T0CON,T0PS1
bcf T0CON,T0PS2
ENDM
timer0.prescale32 MACRO ;Prescale 1:32
bcf T0CON,T0PS0
bcf T0CON,T0PS1
bsf T0CON,T0PS2
ENDM
timer0.prescale64 MACRO ;Prescale 1:64
bsf T0CON,T0PS0
bcf T0CON,T0PS1
bsf T0CON,T0PS2
ENDM
timer0.prescale128 MACRO ;Prescale 1:128
bcf T0CON,T0PS0
bsf T0CON,T0PS1
bsf T0CON,T0PS2
ENDM
timer0.prescale256 MACRO ;Prescale 1:256
bsf T0CON,T0PS0
bsf T0CON,T0PS1
bsf T0CON,T0PS2
ENDM
;Macros to configure interrupts
timer0.highPriority MACRO ;Set timer0 interrupt priority high
bsf INTCON2,TMR0IP
ENDM
timer0.lowPriority MACRO ;Set timer0 interrupt priority low
bcf INTCON2,TMR0IP
ENDM
timer0.interruptEnable MACRO
bsf INTCON,TMR0IE ;Enables the timer0 interrupt.
ENDM
timer0.interruptDisable MACRO
bcf INTCON,TMR0IE ;Disables the timer0 interrupt.
ENDM
timer0.clearInterruptFlag MACRO ;clears the timer0 interrupt flag
bcf INTCON,TMR0IF
ENDM
;Macro to check if interrupt has occured.
timer0.ifInterrupt MACRO tmrservice ;Check Timer0 overflow
btfsc INTCON,TMR0IF
goto tmrservice
ENDM
MAIN.ASM
#include "p18f452.inc"
#include "defs.inc"
#include "macros.inc"
;Define Xtal
Xtal EQU 8000000
PLL=FALSE
;Compute the clock time period
IF PLL
@clock_period SET 1/Xtal
ELSE
clock_period SET 4/Xtal
ENDIF
;Declare Global Variables
global terminate,test1,test2,test
;Get external labels
extern delay, highPriorityInterrupt, lowPriorityInterrupt
;Allocate memory to variables
mainData udata
var1 res 1
tempData udata_ovr
w_shadow res 1
test1 res 1
test2 res 1
test res 1
;Interrupt Vectors
resetV CODE 0X0000 ;Interrupt Vector
goto main ;Goto mainroutine
highInterV CODE 0x0008 ;High Priority Interrupt Vector
goto highPriorityInterrupt
lowInterV CODE 0x0018 ;Low Priority Interrupt Vector
goto lowPriorityInterrupt
;Main routine
mainCode CODE ;The main code.
main: ;Initialize Interrupts
interrupts.globalEnable
interrupts.priorityEnable
interrupts.peripheralEnable
timer0.highPriority
timer1.interruptEnable
timer1.highPriority
;Initialize Timers
timer0.timer
timer0.8Bits
timer0.prescale4
timer0.enable
;timer1.timer
;timer1.8Bits
;timer1.prescale8
;timer1.disable
movlw 0x01
movwf test1
movwf test2
movwf test
terminate: bra terminate
END
SUBROUTINE.ASM
;Declare labels global
global delay, highPriorityInterrupt, lowPriorityInterrupt
;get labels from other files
extern terminate,test1,test2,test
;Define Variables
subData udata
delayCount res 1
pwmDuty res 1
timeTicks res 1
;Subroutine Code.
subroutine CODE
;Interrupt Service Routines
highPriorityInterrupt:
incf test
timer0.ifInterrupt masterTimer
;timer1.ifInterrupt timer1int
retfie
lowPriorityInterrupt:
retfie
;This is a subroutine to create a delay.
delay: movwf delayCount
delayLoop: decfsz delayCount
bra delayLoop
return 1
;Subroutine to handle hardware timer interrupts.
hwtimer:
return 1
masterTimer:
nop
incf test1
retfie
timer1int: nop
timer1.clearInterruptFlag
incf test2
retfie
END
