Timerinterupt with 16F628A and Oshonsoft
revave
I need some help to create an interupt for every second.
Therfore i want to use an internal timer (TMR0 or TMR1).
The hardware consists: 16F628A microcontroller, external crystal 8MHz.
Used software: Oshonsoft PIC Simulator
Ho do I program the internal timer so that every second an interupt appears?
And how to calculate presets if anaother crystal wil be used?
Are you using Basic or Assembler in Oshonsoft.??
I am using the Basic-compiler..
With a 8Mhz crystal , the internal clock period will be 0.5uSec
Using Timer 1 [16bit], set the prescaler to 8, this will give a clock period of 4uSec.
If you load Timer1 counter with 0000, you will get 65536 counts before it 'rolls' over and generates an interrupt, this will be a total time of 0.262144 Secs.
So make the total time equal to 0.25Secs, you need to load Timer1 counter 65536 - 62500 =3036 decimal or 0x0BDC.
So at the 0.25S interrupt inc or dec a counter, so that at every 4th Interrupt it will be 1 Second interval.
In the initialising section of your program you must enable the Tmr1 and Global interrupts.
Define CONF_WORD = 0x3f31
AllDigital
Dim intrcnt As Byte
TRISB = 0x00
'adcon1 = 0x84
T1CON = 0x30
T1CON.T1OSCEN = 1
T1CON.TMR1CS = 0
T1CON.TMR1ON = 1
TMR1H = 0x0b
TMR1L = 0xdc
INTCON.GIE = 1
INTCON.PEIE = 1
PIE1.TMR1IE = 1
PIR1.TMR1IF = 0
Enable
loop:
Goto loop
End
On Interrupt
Save System
PIR1.TMR1IF = 0
intrcnt = intrcnt + 1
If intrcnt = 4 Then
intrcnt = 0
Break  '''  TEST ONLY,,  your 1 second code here
Endif
TMR1H = 0x0b
TMR1L = 0xdc
Resume
  • OneSecIntr1.bas
Hello Eric,
Thank you very much for your fast reply!
1: I have one question about the calclulation. How is the clock period calculated to 0,5uS with a 8 Mhz crystal?
2: Where do you set the prescaler to 8 in the program?
Below your code with some comment with my questions. I cannot find this instructions in the manual and I'd like to now the meaning of he instructions.
Best regards,
Reijnko Vast
Define CONF_WORD = 0x3f31 'What's the meaning of this instruction and why this value?
AllDigital
Dim intrcnt As Byte
trisb = 0x00
'adcon1 = 0x84 'can be used for using an anolog input??
T1CON = 0x30 '??
T1CON.T1OSCEN = 1 '??
T1CON.TMR1CS = 0 '??
T1CON.TMR1ON = 1 '??
TMR1H = 0x0b 'high byte of countvalue
TMR1L = 0xdc 'low byte of countvalue
INTCON.GIE = 1 '??
INTCON.PEIE = 1 '??
PIE1.TMR1IE = 1 'enable timer 1??
PIR1.TMR1IF = 0 'set countervalue to 0 ??
Enable
loop:
Goto loop
End
On Interrupt 'every 0,25 second
Save System '??
If intrcnt = 4 Then '= 1 second
intrcnt = 0
Endif
TMR1H = 0x0b 'load new values to counter
TMR1L = 0xdc 'load new values to counter
Resume
Hello Eric,
The PIC divides the frequency of the external crystal by 4, so the 8MHz becomes 2MHZ which has a period of 500nS [ 0.5uS]
2: Where do you set the prescaler to 8 in the program?,,,, see below
Best regards,
Reijnko Vast
Look at the CONFIGURATION REGISTER in the 16F628A datasheet
AllDigital
This is an Oshonsoft command which sets ADCON so that the PORTA is digital
NOTE: the 628A will initialise to using the Comparators for PORTA, so AllDigital will over-ride
Dim intrcnt As Byte
trisb = 0x00
'adcon1 = 0x84 'can be used for using an analog input??
T1CON = 0x30 '?? sets T1CKPS1 and 0, which sets the pre-scale to 8
INTCON.GIE = 1 '??
INTCON.PEIE = 1 '??
The PIC divides the frequency of the external crystal by 4, so the 8MHz becomes 2MHZ which has a period of 500nS [ 0.5uS].
The answers to the other questions you ask are all in the datasheet.
Hello,
Thank you.
I've looked to the datasheet and its all clear now.
Thank you very much for your very fast help!!
Reijnko
