Hi everyone,
My dad loves his car and since he's retired he can spend a lot more time with it than when he was working. I saw this Velleman K2543 kit which is a electronic ignition amplifier, similar to the ignition boxes you see in high performance muscle cars.
I don't have too much faith in the junk Velleman bundles in their kits, and I'm less comfortable with them running the ignition system on a car...so I'm going to etch the PCB myself and source the components myself also.
There's one problem. I was able to find every component except for a Darlignton transistor called the TIP162, which was originally manufactured in the 70s by Bourns. They are no longer made, and any replica you buy of it is from either NTE or some no-name brand. I'm not comfortable with using those either. (I can't imagine Velleman is packaging a genuine Bourns chip either.)
So, my question is: Can I choose a different Darlington NPN transistor with specifications exceeding those of the TIP162 and drop it in?
I found this ST Darlington that has Max operating specs that are much better than the TIP162: https://www.mouser.com/ProductDetai...=sGAEpiMZZMupZfs/wBb3DGpkiAxa96AGlAaesqTuzAc=
Can I simply use this one instead? I don't know how Darlingtons work, so I'd be curious if I could just use that BU941 from Mouser. Is it possible?
Thanks.
Thanks.
