I too read the tales of woe - and tried them both with, and without, the capacitors - in both cases they worked fine (at least while using a PIC).Here is my tale of woe regarding TM1637 modules. Ignore my above comments at your own peril, even if Nigel Goodwin is certain "that they work fine." In at least some cases too large of filter caps have been installed. This was the case with the modules I purchased, and similar results have been reported in Arduino forums where the modules only operated at extremely reduced clock rates.
So the modules you had worked fine with or without the caps, and by that you make the blanket statement "They work fine", discounting any possibility that others' experiences are true?
No. What you proved by your test was the caps on the boards you have were of the proper value.
I'm not trying to be argumentative, but your tendency to discount any experience that doesn't agree with your own isn't entirely helpful.(smiley face makes this non-rude).
Looking at datasheet specs
Rout = 100 Ohms approx @ 5V based on Vol/Io
CL= 100 pF times 100 ohms = 10 ns so I expect no problems for < = 10 Mb/s perhaps more
As I've clearly repeated, if it doesn't work, try removing the caps - no need to remove them if it's going to work anyway.Probably true, IF THE CORRECT CAPACITORS ARE INSTALLED. This was NOT THE CASE in the modules I and others have had.
I posted a warning of a known problem. Not always the problem, but a possible problem to check for.
Now, both you and Nigel have stated this isn't a problem. Well done.
Please do not misunderstand what I wrote.Probably true, IF THE CORRECT CAPACITORS ARE INSTALLED. This was NOT THE CASE in the modules I and others have had.
