to transmit a message or byte on serial port directly on hyperterm
kavitha nair
dear sir
I require to transmit a sentence or byte data to serial port.
next I also require to read data from other controller connected on serial port.
I have tried transmitting 'A' and 1 and it worked.I am trying simple program to send message given in mazidi. no errors generated but no output also.not getting what will be required.
my program is attached
thanking you
regards
kn
  • sbuf_char11.txt
for(z=0;z<5;z++)
   SBUF=fname[z];}
   while(!TI=0)     //............ WRONG!!  "while(!TI == 0)" This is equality..
   TI=0;          // ..... This is assignment!!
You don't need the "TI = 0;" anyway..
Try this code the while statement shouldn't include the "TI = 0;"
for(z=0;z<5;z++)
   SBUF=fname[z];}
   while(!TI);
   TI=0;
Yes when a byte is transmitted, TI bit will become 1, so you should wait untill TI become high. As Ian mentioned instead of while(!TI=0) it should be either
while(!TI); or while(TI == 0);
Also there is slight problem is seeing that one additional closing curly bracket just in the end of SBUF=fname[z]; statement. you require to remove this , otherwise for loop will contentiously update the SBUF register before the data get transmitted, without checking the TI bit
No!! That was my fault.... Don't know how that got in there....
No Ian , That bracket is also there inside Kavitha nair's attached code file. May be she tried the same code, which won't give a result.
