mstechca
It seems that now in my final designs, I get an occasional transistor to burn out. When I replace it with a newer one, and the same model, it works. Unfortunately, I don't have new ones now, and will buy some later on. In my circuit, I use 2N2222's, 2N4403's and one PN3563 (for the superregen detector).
It turns out that the PN3563 1/2 the time fails to work (even with the digital station circuit removed). I am starting to think that excessive heat could cause the problem.
I am using a 45W soldering iron (which is about 1/3 hotter than most pencil irons) because it melts solder quickly and easily.
Do you think I should go down to a 15 or 30W iron?
I'm starting to get concerned with that transistor.
