Hero999
Banned
Has anyone here tried adding a release agent to plain paper to improve the toner transfer process?
If you know about relase agents then you can skip the next three paragraphs highlighted in blue; I don't want to bore you.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What's a release agent?
A release agent just makes it easier for the paper to come off leaving the toner stuck.
How does it work?
Suppose you cover the paper with water soluble PVA glue, leave it to dry and print on it; the toner isn't stuck to the paper but the PVA glue. When you iron it to the board the toner will stick to the board. Now when you soak it the PVA will dissolve, making it very easy to remove the paper.
The release agent doesn't need to be too special, it just has to be comparable with the printer, withstand ironing and dissolve in a solvent that doesn't attack the toner (preferably water).
I haven't tried thie myself but I'm willing to give it a go. I know there's been talk of waxed paper and glue stick in other threads but has anyone tried anything else?
How does it work?
