Please be gentle. I am a DIY'er who knows a little about a lot of things but I am not an electronics professional. I know diodes, resistors and capacitors and can solder. I am trying to modify an AC welder to a DC welder as per instructions in multiple youtube videos like this one here both done by EE's. One mentions the use of a toroid transformer but I am at a loss to understand how to integrate it into the system. I have one pictured below from an old audio amp. However, I also see that in a few of these vids they just wire a "choke" in line using 8g wire. Should I just strip off all of the wire from the toroid and wrap 8g wire around the bed and splice it in? Still not really sure what it's doing but that is probably a lot easier. I have a 200 amp rectifier and a 100K uf 50V cap. I also know I need to wire in a bleed resistor on the caps for safety even thought he doesn't mention that. The mod also calls for another 24V transformer to power the wire feed motor relay whose output is affected when using power from the main transformer but that I think is an easy mod.
I guess my question is, is the toroid doing the same thing as an induction coil I could make just using the bed inside the toroid and some 8g wire, and what size resistor should I get to bridge and discharge the cap so I don't accidentally stop my heart???
![wP8UdmSm.jpg](https://i.imgur.com/wP8UdmSm.jpg)
