Touch sensor light control needed
geemer
I'm looking for a way to construct a "touch control" circuit for 120v light fixtures that I am fabricating. The light would go on or off when the metal base is touched. There are commercially available ones that screw into the light fixture but these are too limited as well as expensive. I need the circuit plans to install one inside the fixture. Thanks for the help.
haello
i just read the above post, and i am also need of ckt of more or less same kind, so is there anyone who can help me out.... i need a ckt which is capable of switching on the other ckt which operate on 230V ac and it should not go off untill and unless it is touched again.
thanx for helping a newbie
I know motorola makes an e-field sensor IC that can detect changes in capacitance of a sensor plate like you describe. When a person touches the plate the capacitance will change.
Brent
Touch sensor
Hello,
You need a 8 pin STK 58C308 ic to drive a BT136, this triac will connect a incandescent lamp in three steps of intensity and then goes off, just touching a metal contact.
It is very difficult to get a datasheet and application notes.I found this forum (in french) , where a person asks for the IC datasheet and is responded sending him a one sheet datasheet.
https://www.abcelectronique.com/archive/sujets_corp/f_20601_20701.phtml
I have some of this ic's in little black boxes with a few components to drive a lamp. They are from " Harrier Int'l Co.,Ltd."
I hope this information may help you.
Regards.
Touch sensor
Hello,
Regards.
Sorry for the double message
Check this URL
Hey buddy,
Just check this URL, and find out if the circuit will be of any use to you.
with regards
anu.
I am looking to buy touch sensor for lamp Type Nr GE-14-1 230V - 50 HZ product Number 1835/02. Where I can get this? Thanks.Regards Bogdan J. CYRSON
i read the post above
may this help u, search the web and find alexan projects and circuits design. i read the same diagram u need in some books of alexan products. may be it is on volume 4 issued
hope u succeed
geemer,
What do you mean by "too limited"? Are they too big, or do you want it to do something besides ON and OFF?
Ken
eric,
D*#n! I hate it when I forget to look at that!:(
Ken
