I once saw this device called a tap lock for cars. It was a type of microphone/vibration sw (I think) that sticks to the inside of your windscreen. It sits there waiting for you to tap out the correct code and would then unlock your car doors if the code was correct. Useful if you locked your keys in. I think it's useful if you want to get rid of the car key completely, and use it to unlock doors as well as fire up the ignition etc.
Anyway I don’t want to buy 1 - And the microphone stuck to the windscreen seems a bit crude.
Would it be possible to build something similar using a touch switch (The keyhole on the drivers side is metal) and getting a PIC to handle the security code bit.
I guess what I'm asking is it possible to turn the key hole on my car into a reliable touch switch so I can drum a code into it to unlock the doors. (tap 3times - pause - tap 2times - pause - tap 4times -- unlock - anything else trips alarm/disables tap lock)
(Every time I look up touch switches I see the same stupid design with two piece of metal and you use your finger to short the two. I'm after a touch switch that works with just 1 piece of metal. I have a touch lamp like that. Even my living room dimmer is like that - so I know it possible.)
Thanks.
Thanks.
