trace size vs. current
wjyates
Hi, every one
first time trying to build my own board
how do we determine how much current can be past through a given size trace
having problem deciding witch relay to use:
1st relay is 25 amp pcb only.would have to add blade power connecters as close
as passable to the relay. hence the first question.
2nd relay is 25 amp pcb w/blade connecters built in on top. but much larger than 1st.
trying to keep board as small as passable
dose tinning add current rating to trace
A google search for PCB trace width calculator brings up a lot of utilities.
Look at this tutorial pdf, pages 6 & 7
E
  • PCBDesignTutorialRevA[2].pdf
Some of my "China PCBs" have very thin copper. I have no solder mask over the high current traces and tinning added. This reduces the resistance slightly, helps spread out the heat a little, and the bumpy surface emits heat better.
On thick copper, i think this tinning helps much less.
