Hello
i wonder if you could tell me if this is a good idea or not.
I want to make a dual tracking power supply with the usual positive and negative outputs.
There are the usual circuits with positive and negative rail regulators such as this (copied from somewhere) with the negative side following the positive side via an op amp.
![basic tracking2.jpg basic tracking2.jpg](https://www.electro-tech-online.com/data/attachments/52/52078-151a2183063b0b4882f531cfcef480e4.jpg)
BUT would it work with two positive rail regulators? The advantages would be (1) there are better LDO positive rail regulators than their negative counterparts and (2) when i add mirrored current limiting i won't have to bother about all the op amps being rail-to-rail (the final version will need 75v op amps for the tracking etc).
here's a basic diagram:
![dual positive rail tracking1.jpg dual positive rail tracking1.jpg](https://www.electro-tech-online.com/data/attachments/52/52079-01d2109bf86d5843cdaa2298a362d40e.jpg)
I breadboarded a test circuit an it worked OK. The inputs are from different transformer windings/rectifiers/caps etc. The op amp inputs and outputs follow down to the negative rail. the inverting and non-inverting inputs are reversed from the first schematic above.
One potential problem is the op amp's supply voltage changes according to the output voltage...
Does this - or anything else - look like a bad idea?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks for any suggestions
Mike
Mike
