hello good people![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I recently got a transformer rated at primary 240VAC-115-0 stepped down to secondary 9VDC-0-9VDC. I assume the ratings are in R.M.S.
I hooked the inputs using the 240VAC-0 line and scoped the output VAC lines. From the scope I expected a 24.45VACp-p voltage (converted from 18V rms amplitude) but I got a peak to peak amplitude of 31volts instead.
Do transformers actually tend to exhibit higher rating than usual or could it be due to tolerance issues? Anyone faced this before??
thanks!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks!
