Transformer problem
smiley325
I was building a little power supply, when my voltmeter probe accidently shorted the center tap of the secondary to the other AC wire. Before the transformer was stepping 120 V mains to 36 V, but after the short I'm guessing some of the turns on the secondary side got fused because now it is stepping 120 V mains down to only 45 V.
Is it still safe to use this transformer?
Thanks in advance,
smiley325
Disconnect it from mains, and using ohmmeter, check for any continuity from Primary to Secondary. Should be open or infinite.
A primary to secondary short should never happen if it's a class 2 isolation transformer.
Clarify
Oh sorry, I should have been clearer: what I meant was I shorted the CT on the secondary to the other wire on the secondary (not sure what its called, I call them + and - but it's AC so...?)
Primary and secondary sides still isolated from each other, open circuit.
a momentary short is unlikely to have damaged the transformer.
any fuses in circuit? DVM can gat confused when one probe is o/c and make up readings.
if in doubt grab an AVO;)
