JAMES IRVINE
I was wondering if anyone can help me to understand a bit about this transformer https://www.electro-tech-online.com/custompdfs/2008/05/38796.pdf it is type 24/6 in the list it has a 0-115v primary rating and a 0-6v secondary rating at 12VA. This is the transformer I have been supplied with to complete my project on the DC to AC inverter which requires a specified 240volts output and I calculated that the current would be 24A but maybe I'm wrong about that. see for yourself **broken link removed**
The question is can I use the secondary as the primary and convert 12 volts into 230 volts at the output. Also the pdf doesnt explain what the four pin connections are for can anyone explain? I'm thinking that this is configured as two transformers in one in which case two pins are live and two are ground is this correct? But which is which?![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
