.... You could use an NPN transistor, which can be turned on with around half a volt. The NPN can be used to control a larger voltage to switch your mosfet....
... although i would need minimum 1.5V also (two schottky diodes from the bridge recitifier, then 0.7V for the transistor), if i had a peak of 2V, it would be on only after passing 1.5V, which isn't a great duty cycle
