ikalogic
transformerless power supply or explosives? ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
hello.. i am trying to build a transformerless 5v power supply that can deliver about 100 to 500 mA (100 mA is a minimum..)
- i don't want to use HI WATT resistor to dispate the excessive voltage...
- I want to use 7805 regulator..
So i thought of a way to try to reduce the voltage from 220 to something like 20 or anything under 35V (which is the max input voltage of a 7805)
here is my base idea..
The resistor R2 is to protect the transistor from the over voltage.. (TIP122 datasheet says MAX VCE = 100 V)
i think that if i adjust (by any mean) the base voltage to smth like 20V, the emitter voltage should be 20 - 2.5 = 17.5 V , which then can easily filtered and regulated though capacitors and a 7805...
i am not quite sure if i shoukd go on and test this on my bread baord...
any advices?
EDIT: i also wonder if i do need a power transistor like the TIP, or a 2N2222 can do?
Don't make me wait for too long! or i'm gonna try this right now.. if you don't see me on the forum again.. you'll know why..![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
