PG1995
Active Member
Hi
I was searching if a transistor is linear device or not. A linear device has a linear relationship between current and voltage (Ohm's law). I'm a beginner in this electricity and electronic stuff. So, please keep your reply simple. Thanks.
While searching I found this:
We will operate transistor mainly in 4 regions, namely active , cut-off, saturation and pinch off region, depending on the type of biasing. If it is under active region then transistor is a linear device (linearity in the sense if the output is proportional to input then it is said to be linear).
So far I only know that a transistor has a collector, base, and emitter points.
It would be extremely nice of you if you could explain it a bit. I would be much grateful.
Regards
PG
Regards
PG
