Transistor potential divider query
UTMonkey
Hi all,
The attached circuit doesn't do anything, its just my attempt to brush up on transistor operation while evaluating some software I downloaded on my android tablet.
The divider is really straightforward, with switch A open there is 100uA .
What I need explaining is the extra current that is drawn in the divider when switch A is closed.
116uA with 33uA going into the base of the transistor and remaining 83uA going through the bottom resistor of the divider.
The divider has not changed at all 50k/50k.
I have already established a relationship between the base current and the collector current (10 to 1) and the emitter current consists of the collector current plus base current.
Any one care to jog my memory.
Regards.
Mark
The current must change because you connect the load. The base current loaded the voltage divider.
And the base current is equal
Ib = (Eth - Vbe)/( Rth + (β+1)*Re )
And
Eth = Vcc * R2/(R1+R2) = 5V
Rth = R1||R2 = 25KΩ
So
Ib = (5V - 0.75V)/( 25k + 101k) = 0.03373mA = 33.73μA
And the base voltage
Vb = (β+1)*Re + Vbe = 101K*33.73uA + 0.75V = 4.156V
Since a certain transistor part number has a wide range of current gain, usually we make the current in the divider 10 times the typical base current. Then the base voltage is almost the same if the transistor has a low current gain or a high current gain.
