TRI T D22-5003 LCD module datasheet needed.
SwingeyP
Hello does anyone have any data for the above LCD please?
on the back there are 2 rows of 9 pins either side of the module.
Many thanks - Paul.
Many thanks I now have the data sheet. What i'd like to find is the header pins to make a motherboard for it to sit on. They're not .1 spacing :-(
I have a box of 50 of them and i'dl love to be able to use them on my robot project. I didn't really want to solder straight to the pins.
Regards - Paul
Same here, I have a box full. 2mm headers are avaialable at Rapid Electronics which may do the job
22-3250, a 40-way PCB socket, I think solder wires to that and plug in GLCD.
So far I've soldered to the D22, written software in PBP and get diddlysquat on display.
I am at the point where I say what's it all for anyway. I've read the data sheet over and over but still
can't make it work!
Mike
Regards - Paul
Sorry just noticed this thread again. Are you still having problems Mike? I haven't tried to program one yet but I have other LCD's working with help from this forum. What's PBP for starters? That's not a helpful start is it really. I have some assembly code I can post and you could maybe compare.
Regards - Paul. (now if someone can just help me with walking gaits we'll all be happy!)
Hi Paul
PBP is PicBasicPro a high level language compiler for PIC micros. I still use a bit of asembler when needed but I moved over from assembler to PBP, I found assembler chellenging but too time consuming. I'm OK with basic alpha/numeric LCDs. I still can't get anything on the D22 grphics display despite going over the data thoroughly. Any help just to get a display going would be good then I can get on with some serious programming.
Rgds
Mike
Hello Mike. Did you ever manage to get one of these displays to go? - I too have read the data sheet with no results. I am also using Pic Basic but the oshon flavour.
Regards - Paul
i already tried with that web-page,but they got nothig for this part number, i´ve even e-mailed but no answer...
...so once again could somebody hepl me?
thanx
D22 5003 LCD modules
Hello Paul
I didn't manage to get LCD to show anything despite studying the data sheets thoroughly, it's a puzzle. Project on back burner for time being, waiting for inspiration.
Mike
LCD Data
Here's what I have rotting79. If you manage to get one going please post the code so we can all benefit.
Regards - Paul
  • D22-5003-03-SPA00%20Final.pdf
Hello does anyone have any data for the Tri-T D22-5002 C00 LCD please?
on the back there are 2 rows of 11 pins either side of the module.
Many thanks - Yasmani.
