triac 24v
It's an AC motor I presume? You should onyl use a TRIAC with an AC motor.
TRIAC - switching speed control
relay - just on or off for continuous periods of time
Tr. = transformer? That's only needed if your source voltage is different from the motor voltage (and you would use it in addition to a switching device).
Regarding the switching speed control, it's not as simple like PWM with DC motors. I don't know much about variable speed AC drives so...Most AC motors are designed for constant speed operation.
I'm assuming this is an AC supply, otherwise you want to use PWM and a MOSFET not a triac.
That depends on whether it's an squirrel cage or universal motor; the latter will work and the former won't.
Yes, a properly rated TRIAC should work just fine. I don't think there is a problem with using a TRIAC that can handle 220V in a 24V circuit as long as you can meet the switching requirements in the same way you can use a 800V FET in a 24V circuit.
24V AC is a bit strange though...
More importantly what sort of AC motor is it?
It will only work with universal motors.
if its a Universal AC-DC Motor, you can also use an SCR (like BT169 , if the current is small ),
but the input AC should be made into pulsating DC using a Full wave bridge rectifier
arun
