Triggering computer controlled igniter with 2 wire magnetic pickup ?
waid786
Hello,
I came accross posting regarding Hall sensor and coil on plug pack which uses 3 wire powered hall sensor.
https://www.electro-tech-online.com/threads/modify-hall-sensor-and-coil-on-plug-pack.133159/
I am attepting to do something similar, however, my distributor has a 2 wire non-powered magentic pickup. I want to use a single GM LS coilpack with built in igniter in my 1964 Ford Falcon which is very similar to the one in the above article for GMC Envoy. I have attached GM LS coil pack wiring diagrams and other pictures.
Below is circuit diagram for a 3 wire +12 powered hall sensor. How can I make it work with a 2-wire magnetic pickup ?
Here is more information on GM LS coil packs.
Thank you!
Waid
