Trim pot specs. need to better understand tolerance
fastline
If looking at a 10K trimmer, the spec only indicates 30%, is this typically a +/-30% adjustment or something else?
You should try not to use the absolute value of a trimpot, but rather a ratio as that is much more precise. Circuits can normally be reconfigured to use a ratio instead of the absolute value.
