Externet
An existent LM4863 power amplifier IC needs to be fed by at least 100mV rms to yield the desired level at the speaker, as probed in its 'normal' operation.
A piezoelectric microphone needs to be applied to the input instead, and thought a 2N7000 N-channel-enhancement mosfet could be of use as single stage preamplifier (as I have 2000+ pieces in need of use)
But no, cannot get a decent level. Would it be possible to use a 2N7000 ?
Battery is 4.0V.
Gate is between 1MΩ to +; and 1MΩ to gnd.
Drain has 1KΩ to + and source 1KΩ to +
Output is after 1μF at the drain.
Any suggestions ? Raise value to both MΩ resistors ? Or is it a lost case ?
Battery is 4.0V.
