Ttl & cmos
Electroenthusiast
Active Member
I have CD4060 a CMOS IC; i'm designing a circuit that uses various TTL IC's, since its not compatible to use TTL with CMOS...
I want the equivalent IC from TTL family.
How can i find it?
Moreover, from the datasheet i find that Maximum Output current for CD4060 is .24mA. Thats unsuitable for my application. So i require TTL IC.
How can i find it?
hi RV,
Look at this datasheet.
and another one.
I know you think I am an old grouch, but you should try to find this information by Googling, rather getting someone else to do it for you.:rolleyes:
  • MM_MM74HC4060.pdf
  • 74HCT4060.pdf
The datasheet of the CD4060 from Texas Instruments shows a typical output current into a 2V red LED of 3.5mA when its supply is 5V and an output current of 14mA to 18mA when its supply is 10V.
The output current is only 0.24mA when its supply is maybe only 3V.
