No, this is not about the mating habits of turkeys <chuckle+smilie>.
What i noticed this year is that small turkeys seem to have a lot of bone, and to be a bit more descriptive they seem to have LESS meat to bone ratio. This also directly translates to less meat to cost ratio which means we pay more for the actual meat on the turkey if it is a small bird.
But what i found on the web is quite varied. Some say the meat to bone ratio is higher for smaller turkeys, but i find this hard to believe based on what i have seen in the past. The smaller bird i got recently (around 10 pounds) had significant bone and it was tough as i was unable to cut through it with a sharp knife when i could cut through a 6 pound chicken with a knife. So the bone is thicker on the turkey for one thing. I should have weighed the carcass but didnt think about it until after it was thrown out and picked up by the garbage collector.
What i found then if i ignore some of the posts i found on the web is the following sumarization:
8 to 12 pounds has lower meat to bone ratio.
12 to 35 pounds has higher meat to bone ratio.
Over 35 pounds the bones have to be stronger so the meat to bone ratio starts to go down again.
Im not really interested in anything over about 25 pounds though.
So what is your take on this?
