Turning a positive vref into a negative reference?
blueroomelectronics
I have a 4.096V reference for a ADC and I'd like a -4.096V reference for the -VREF on the ADC.
Question would an OpAmp do the trick or do you have a better suggestion / idea?
An op amp connected as a unity gain inverter will work well. Depending on the accuracy you require, you may need a low offset, low noise op amp, and precision resistors (perhaps 0.1% tolerance, or 1% resistors with a trimpot) to accurately generate the voltage level.
There are other methods, such as a flying capacitor switch, to invert the voltage, but that is more complex and has its own accuracy and noise concerns.
I don't see why you need a negative reference, you can easily bias an ADC input so it can measure negative voltages.
Can the Vref be wired like a zener?
I.E.
Vref Vdd to +supply,
Vref Output to ADC Gnd,
Vref Gnd to ADC -Vref plus a resistor to -supply
Opamp will introduce inaccuracies unless you get something with nice DC specs. If it is a shunt reference I would to what Pommie suggests and just use two.
Hi Bill,
in order to invert an OpAmp for negative output you must use a negative supply voltage anyway. Use an LM7905L and trim the output to the desired value.
Regards
Hans
