two 7-segment
Jan De
Hi guys
I did a circuit to interface 7-segment with 8255 PPI ( which is inside the MTS trainer ) .. and I made this assembly program codes to display the number from 0 to F , and it work fine ..
But now I have to use ( two ) 7-segment displays to show numbers from 00 to 99 ( 00- 01- 02 .... 99 )
so How can I modify my codes to satisfy this purpose ?!
_______________
PORTA EQU 0FFF9H
PORTB EQU 0FFFBH
CNT   EQU 0FFFFH
CODE      SEGMENT
               ASSUME   CS:CODE, DS:CODE
      ORG 0
START:       MOV DX, CNT      ; this part for sending the control word
                  MOV AL, 80H
                  OUT DX, AL
J1:    MOV BL,16
        MOV SI, OFFSET FONT
       MOV DX, PORTB     ; turn ON the FND
       MOV AL, 11H
       OUT DX, AL
J2:   MOV AL, [SI]
       MOV DX, PORTA
       OUT DX, AL
      MOV CX, 0FFFFH
      LOOP $
     INC SI
     DEC BL
     JNZ  J2
            ;    PGFEDCBA
FONT    DB   11000000B    ;HEXA0
           DB   11111001B    ;HEXA1
           DB   10100100B    ;HEXA2
           DB   10110000B    ;HEXA3
           DB   10011001B    ;HEXA4
           DB   10010010B    ;HEXA5
           DB   10000010B    ;HEXA6
           DB   11011000B    ;HEXA7
           DB   10000000B    ;HEXA8
           DB   10010000B    ;HEXA9
           DB   10001000B    ;HEXA A
           DB   10000011B    ;HEXA B
           DB   11000110B    ;HEXA C
           DB   10100001B    ;HEXA D
           DB   10000110B    ;HEXA E
           DB   10001110B    ;HEXA F
CODE  ENDS
END START
_______________________
please help
jan de,
Your link isn't good. You have to do a copy link location if it was from another VB based forum software.
But, probably, you have to multiplex the displays. The displays can be common anode or common cathode.
The segments to all of the displays are basically turned on all of the time.
repeat: Turn off all digits for a short time, change the segments(for digit 1); turn on digit 1, Wait(display time); turn off all digits; Wait(inter-digit blank); change the segments (for digit 2), wait(display time) turn on digit 2; Until
If you don't do inter-digit blanking, the segments will tend to blur a bit.
Your link still getting a problem,
i recommend you to have a look on the components , and check whether they are common cathode or common anode configuartion.
I'm sorry I just have attached the picture..
they are common anode ,, I just wanna know how to make them display numbers from 00 to 99
yesterday I made this code and I don't know if it will work for that purpose or not
PORTA EQU 0FFF9H
PORTB EQU 0FFFBH
CNT   EQU 0FFFFH
CODE      SEGMENT
      ORG 00
START:            MOV DX, CNT
                  MOV AL, 80H
                  OUT DX, AL
J1:     MOV CL, 100
        MOV SI, OFFSET FONT
        MOV CH, 0
  J2:    MOV AL, CH
         MOV BL, 10
         DIV BL    ; AL= AL/10 AH= AL%10
         PUSH AX
         MOV AH, 0
         MOV SI, AX
         MOV AL, 01H
         MOV DX, PORTB
         OUT DX, AL
         MOV AL, [SI]
         MOV DX, PORTA
         OUT DX, AL     ; FIRST DIGIT
         CALL DELAY
         MOV AL, 02H
         MOV DX, PORTB
         OUT DX, AL
         POP AX
         MOV AL, 0
         MOV SI, AX
         MOV AL, [SI]
         MOV DX, PORTA
         OUT DX, AL     ; SECOND DIGIT
         CALL DELAY
         INC CH
         DEC CL
         JNZ  J2
DELAY :    MOV CX, 0FFFFH
           LOOP $
            ;    PGFEDCBA
           DB   11111001B    ;HEXA1
           DB   10100100B    ;HEXA2
           DB   10110000B    ;HEXA3
           DB   10011001B    ;HEXA4
           DB   10010010B    ;HEXA5
           DB   10000010B    ;HEXA6
           DB   11011000B    ;HEXA7
           DB   10000000B    ;HEXA8
           DB   10010000B    ;HEXA9
CODE  ENDS
END START
Links are OK now. My instructions are still true. Just make sure that you can turn on each display by manipulating PB1 and PB2.
Then you will need a way to do timing on the order of milliseconds toggling PB1 or PB2 and go from there.
Try writing a simple program that can blink a single segment or rotate a few segments on one digit.
