two lines are perpendicular only when...
PG1995
Active Member
Hi
Please have a look on the attachment. You can find me query there. Please help me with it. Thank you.
Regards
PG
In your particular case (the slope is 45 degrees) -y/x is same as -x/y. In another words: x=y.
When you have a line 'a' with a slope y/x, line 'b' is perpendicular to it if its slope is -x/y.
PG1995,
Line l2 is 135°, not 90° as shown in your diagram. Why do you use a symmetrical diagram when an unsymmetrical diagram would immediately remove your confusion? Take 30° and 120°. tan 30° is y/x = 0.58.
tan 120° is x/-y = -1.73 . So, (y/x)*(x/-y)=-1 = 0.58*(-1.73) = -1 .
Ratch
From [LATEX]Tan 45=\frac{y}{x}[/LATEX] we get [LATEX]y_1=xtan45=x \therefore \frac{dy_1}{dx}=1[/LATEX]
And similarly [LATEX]y_2=-xtan45=-x \therefore \frac{dy_2}{dx}=-1[/LATEX]
[LATEX]\frac{dy_1}{dx}\cdot \frac{dy_2}{dx}=-1[/LATEX]
I can't quite figure which step is incorrect in your working.
I think Ratchit explained it better.
There is no error, just a confusing example (as Ratch already pointed out). In the example case -y²/x² = -1
Thank you, everyone.
Yes, The example I posted wasn't a good one. It didn't remove any confusion.
tan(33)*tan(57) = 1 = tan(33)*{1/tan(33)}
tan(57) = 1/tan(33)
You can use any other angles in place of 57 and 33 (they should sum up to 90).
tan(x) = 1/tan(y) [y+x = 90]
How do I reach this result? Please help me with it. Thanks.
Regards
PG
What result? do you mean: tan(x) = 1/tan(90-x)
Sorry for the confusion.
I'm saying that how do I prove that RHS equals LHS in: tan(x) = 1/tan(90-x)? Please let me know if you need further clarification. Thank you.
Regards
PG
