could you use those cheap wireless transmitters? have a control board near the relays? or maybe RS232, 500 feet should be no problem at low speed, or have I missed something? I get the feeling I am not understanding the question correctly, so ignore thisAny ideas on the most ecinomical way to control relays from 500 feet using only two wires?
This will be a 12-24 volt system using up to 500 I/O channels.
I am looking to control sets of 32.How many relays ?
I want to stay away from wireless, its for pyro and our current wireless systems have proven unreliable.could you use those cheap wireless transmitters? have a control board near the relays? or maybe RS232, 500 feet should be no problem at low speed, or have I missed something? I get the feeling I am not understanding the question correctly, so ignore this
I would suggest RS485. It is pretty much the standard for two wire data communication in industrial environments.
Have you Googled?: pyrotechnic controller circuits
Ken
In a field somewhere. We use 18 gauge zip cord or lamp cord Now.What type of environment?
Inside a building? In a field somewhere?
pole line?, underground cable?, coax?
eT
Dude I am a pyrotech!Have you Googled?: pyrotechnic controller circuits
Ken
We like orange, LOLTheres a fault on that, wrong shade of yellow.
Here is a good primer on E-Matches as we call them;olimax do a web server board with 2 relays but a number of outputs, not sure how many but the boards are cheap, adding relays to the outputs would be very easy, also look to see if VELLEMAN have anything, they are very cheap and have all kinds of funny kits with relays.
how much current is needed to fire whatever you use to light the fuse?
Vellman has a 2 wire kit but its only 10 relays and has a limited distance between the controller and the remote.olimax do a web server board with 2 relays but a number of outputs, not sure how many but the boards are cheap, adding relays to the outputs would be very easy, also look to see if VELLEMAN have anything, they are very cheap and have all kinds of funny kits with relays.
