TX RX HC-12 radio module
camerart
I've set up a couple of PICs with HC-12 radio modules. They are sending HSEROUT messages i, e, 'Hserout "PRESS ", strpr, CrLf ' which show on a SERIAL TERMINAL (Teraterm, Putty, Termite) With a number being sent "1", 1 or "2", 2 and setting 'i' as BYTE and STRi as STRING.
I've tried lots of variations!
I've tried to use HSERIN, HSERGET on the receiving PCB to do anything like switch a LED etc, but can't get it to work.
Here's some of what I've tried:
main:
stri = #i
Hserget i
If i > 0 Then
Hserout "Number: ", #stri, CrLf
WaitMs 50
'WaitMs 1000
Endif
Goto main
End
'Dim i As Byte
'Hseropen 19200
'loop:
'Hserget i
'If i > 0 Then
'Hserout "Number: ", #i, CrLf
'WaitMs 50
'Endif
'Goto loop
Any ideas please.
Camerart.
Hi I,
So I can prove the RX is receiving ok, is this ok?
loop:
Hserget i
If i > 0 Then
Hserout "Number: ", i, CrLf
LED = 1
WaitMs 50
Endif
ELSE
LED = 0
ENDIF
Goto loop
Then SEND 0 or 1 from TX?
EDIT: I'll double check the PCB connections, as it's an old PCB, with previous alterations.
C
Hi I,
So far I've got them to switch ON and stay ON, and not switch ON, but I can't get them to alternate ON/OFF
Can you show me the code for what you sent from the TX to get yours going please?
I've tried this:
main:
i = 0
rled = 0
yled = 1
Hserout i, CrLf
WaitMs 5000
i = 1
rled = 1
yled = 0
Hserout i, CrLf
WaitMs 5000
Goto main
'0' and '1' show on the Terminal.
C
Look at your first code..
loop:
    Hserget i
    If i > 0 Then
       LED = 1
       WaitMs 50
    ;Endif <------ Shouldn't be here..
    ELSE
       LED = 0
    ENDIF
Goto loop
Two things....
First ) You can't "ENDIF" and then "ELSE"..
Second) The LED will be on for less than a micosecond
loop:
    Hserget i
    If i > 0   Then
       If LED = 0
          LED = 1
         WaitMs 50
      ELSE
         LED = 0
      ENDIF
   ENDIF
Goto loop
now LED will toggle when a character is bigger than 0 come in
Hi I,
What are you sending to the RX?
or Hserout i, CrLf
or Hserout "1 ", CrLf
or Hserout 1, CrLf
C
Not sure what you are saying... I thought this was the receiver?
The PC sends any character and the LED turns on, then any other character turns it off!
Hi I,
I have two HC-12s on PCBs One TX and and the other RX.
I've tried many combinations of SEND and RECEIVE, and got the RX LED to switch ON, but not ON/OFF
How do I switch 'say' a LED ON/OFF by sending different numbers?
NOTE: Your last suggestion #6, didn't compile in Oshonsoft. It didn't like 'If LED = 0' for some reason.
C.
loop:
    Hserget i
    If i > 49   Then     ; <----- 49 is number 1
          LED = 1
          WaitMs 50
     ENDIF
    If i > 48  Then   ; <----- 48 is number 0
          LED = 0
          WaitMs 50
   ENDIF
Goto loop
Now ascii 1 switches it on and ascii 0 switches it off
Send
Hserout "1" or Hserout "0" to switch... if your not sure, send numbers 48 and 49
loop:
    Hserget i
          LED = 1
          WaitMs 50
     ENDIF
          LED = 0
          WaitMs 50
   ENDIF
Goto loop
Send
Hi I,
That answers the odd large number, I occasionally saw i,e, 75 (from memory)
I'll try your code tomorrow, thanks.
C.
Hi I,
Your code show both 'If i > 48' also 'If i > 49' is this correct?
At the moment the RX LED is switcing ON but not OFF.
I've also tried 72 and 73 DEC
EDITED
C.
I've tried many variations of the above code, but nothing switches the RX ON/OFF yet.
If I use this: and keep resetting the RX the YLED switches ON or OFF 50% of the time, and the RLED is always ON.
C.
TX:--------------------------------------------------------------------------------------
For x = 0 To 1000
rled = 0
yled = 1
Hserout "0", CrLf
Next x
For x = 0 To 1000
rled = 1
yled = 0
Hserout "1", CrLf
Next x
RX:--------------------------------------------------------------------------------
Hserget i
If i = 0 Then '< --- -- 48 is number 0
rled = 1
WaitMs 500
Endif
If i = 106 Then '= 106 Then '< --- -- 49 is number 1
yled = 1
WaitMs 500
Endif
C.
For x = 0 To 1000
rled = 0
yled = 1
Hserout "0", CrLf
Next x
For x = 0 To 1000
rled = 1
yled = 0
Hserout "1", CrLf
Next x
Hserget i
rled = 1
WaitMs 500
Endif
yled = 1
WaitMs 500
Endif
"0" is 48 decimal
"1" is 49 decimal
What is IF i= 106??
What do you mean by Rx on/off?
Does it mean rled on/off?
My code uses 48 ( ascii 0) and 49 ( ascii 1) It works because I tested it!!
ASCII 48 to 57 are numbers 0 to 9 ..
You can also do this
if i = asc("1") then....
Then you dont have to remember stuff
Hi I,
Anything to save me remembering stuff is welcome.
TX is sending "0" or "1" depending on a BUTTON press, and can be seen on my terminal
RX turns on RLED or YLED depending on TX "0" or "1" but needs to be reset to change.
RX LEDs don't always come on after reset, approx 50%, but if they do they are the correct colour
RX CODE---------------------------------------------------------------------------------
main:
Hserget i
If i = Asc("0") Then '< --- -- 48 is number 0
rled = 1
WaitMs 500
Endif
If i = Asc("1") Then '< --- -- 49 is number 1
yled = 1
WaitMs 500
Endif
Goto main
"0" is 48 decimal
"1" is 49 decimal
What is IF i= 106??
Hi J,
The reply in #18 is after more tests, where I found the RX needs to be switched ON/OFF (reset) to get the LEDs to switch. (and then only 50%, but always if they come on they are the correct colour)
I tried I's <48 <49 and asked why they are both <, if you understand what I mean? Then after lots of < and > I arrived at 106, which worked for some reason, but ignore all that as now I use I's suggestion of Asc("1").
Hope all that is clear.
C.
There are hundreds of ASCII tables online to check the relating numbers..
But!! I imagine this is for testing, because you can't easily send non ascii characters from a PC..
Yeah!! Sorry about that... I tested it with "If i = 48 then" Hey! with help like mine you are definitely kept on your toes!!
