TX_test program in PIC C
flemmard
hi all,
The code below is not working...Can anyone advice on this.I'm using PIC16f877.
#include <pic1687x.h>
#include <pic.h>
// Transmitter test program
void main() {
    TRISC = 0x00 ; //portC as output
	SPBRG = 129;	// Set the baud rate to 9.6k
	BRGH = 1;		// Set high baud rate
	SYNC = 0;		// Set asynchronous
	SPEN = 1;		// Enable serial port pins
	SREN=0;
	TX9 = 0;		// Disable 9 bit transmission
	TXIE = 0;		// Disable tx interrupts
	RCIE = 0;		// Disable rx interrupts
	TXEN  = 0;      //reset the transmitter
	TXEN = 1;		// Enable the transmitter
	while(1) {
	    TXEN  = 1;
		while(!TXIF) {	// Checks if the transmit flag is down
			continue;
		TXREG = 0b01010101;
TX and RX have to be set to input for the UART to work. You should also write to TXREG and then wait for TXIF to be set.
Hi, thanks for your reply ! Can you please send me your code if you have some sample?
I only use asm on 16F pics but I would guess it would be something like,
#include <pic.h>
void main() {
	TRISC = 0xc0 ; //portC as output
	SREN=0;
	while(1) {
		TXEN  = 1;
		TXREG = 0b01010101;
		while(!TXIF); 	// Checks if the transmit flag is down
I am compiling a Problem-Issue Verses Effort-Issue report.
I will incorportate this example as an Effort-Issue.
#include <pic.h>
void main() {
	SREN=0;
	while(1) {
		TXEN  = 1;
		TXREG = 0b01010101;
Hi , can you send me your asm code to to test my tx ?
I understand that i can add that asm code directly to my C for compilation
Thanks in advance
