Typical IR LED; what is the voltage drop & max current?
Seems I'm looking in the wrong place on Google for IR LED datasheets. I do recall they can be used at upto 100ma (50% duty cycle?) are they 1.2v drop? 1.7v?
Re: Typical IR LED; what is the voltage drop & max curre
You need to look for the specific one you have, try LD274 for one I happen to be using at the moment. I'm running it off 3V (2xAA) from a 16LF628, using an NPN driver with a 6.8 ohm series resistor.
It's normal to pulse tham around 1A, with a fairly low duty cycle.
The voltage across the LED will be 1.9V with a forward current of 1A. And note the 100 us pulse requirement, ie. the 1A must not be on for longer than 100 us.
With a current of 100 mA it will be 1.3V, note the 20 ms pulse.
Given the brief extract quoted, these appear to be typical figures. The maximums are 1.5 V and 2.5V respectively.
I mean tp/T. Typically what should I set in 100mA 20ms, or 200mA ~10ms, or 1A 100us?
In 20ms 50% or 20%?
Or in for example 500mA ?
In 20ms 50% or 20%?
Again, you do not talk in English.
What do the 3 letters tp/T mean in English words?
Oh, I think you are asking what pulse width for certain LED currents?
The datasheet should say. The example that was posted shows a max of 100mA for 20ms or 1A for 100us.
Yes, my english is not the best :D. I am interested by the pulse width, I[A] and the lighting time (perhaps a typical caracteristics with different pulse width curves). I have some 5mm IR LED at home, they are different types and I dont know the exact type. That's why I ask the typical datas of an IR led.
We do not know the spec's for your IR LEDs.
Buy new LEDs that come with important datasheets.
