UK Supplier
holdit
Greetings
Could anyone tell me a UK supplier that stocks 16f84
with a telephone order Number
Ive been googleing for hours trying to find one with no luck
Cheers
holdit said:
Greetings
DON'T use the 16F84, it was replaced by the cheaper, higher spec, 16F628 last century! - use that instead!.
But BOTH are available from Maplin, the 16F84 at £4.13 and the 16F628 at £2.77 (or even the 16F627 at £2.43).
I can also recommend the following as I have ordered from them:
For terms and condictions and delivery charges, click the "HELP" sidebar and scroll down the page. In my previous ordering, the p+p charge is IIRC less than £2.
Thanks for replys
iam very new to electronics etc so ive been looking at code to control a servo using vb and thats what i found and it uses the 16f84 chip and most sites i found recommend that chip also to learn on :)
thats again for the reply
cheers :) :)
cornhill looks good to me thanks :)
holdit said:
Thanks for replys
The sites that recommend the 16F84 for learning on are sites from the last century!, you should use it's more modern replacement instead - there's almost NO difference in the code.
