Understanding a simple electronic device
morphex
Hi.
I've studied a little about electrical and electronical devices, and this Christmas I bought a simple kids set to create an alarm from scratch.
I was wondering if you could help me understand how it works.
See attached photos on my Google Drive:
Points 15-16 are an alarm enable/disable switch, points 8 and 12 are for connecting to a simple on-off sensor.
-Morten
Basically "walk" the path, starting at + of battery (red lead) and see where it takes you.
If you come to a switch think bridge when its closed, no path if its open.
And see how you get all the way back to the - lead of the battery (black lead).
If you walk a path that goes thru switch, an R, an LED and get back to - lead of
battery then LED is lit when path is continuous, eg. switch is closed.....
Note LED is a diode, so it is polarity sensitive, one way no current will flow thru
it, polarity opposite configured it conducts and lights up.
Regards, Dana.
Hi M,
Note, that an LED must have a current limiting resistor in line with it to keep the current at the correct level, so don't connect a battery straight across the LED or it will glow too brightly for a very short time.
C.
