This might be a super obvious question to most over here, but I know nothing about power supplies, so please bear with as I try to explain what is going on.
I have one of these SPS705 68VDC power supplies running inside a rather simple stepper motor control box:
http://www.leadshine.com/productdet...unregulated-switching&series=SPS&model=SPS705
This powers up a DM856 stepper driver (also made by Leadshine) which is then connected to a SY57STH56-3008B Nema 23 stepper. There's also a 24VDC indicator sitting on the 68VDC input line into the DM856, this is wired via a zener diode to drop the voltage to not fry the 24VDC lamp. The main AC supply is connected to the PSU via a rotary isolator and powers up both the SPS705 as well as a servomotor controller (there's an AC filter mounted just after the isolator to stop any noise getting back into the line).
The workload on the above is very minimal as it's only powered up 2-3 times a day max and only for a few minutes. The Nema 23 stepper never really works under any heavy load either (indeed the 68VDC PSU is way overkill for what this stepper does), it only rotates a few steps left or right and that's it, the servo runs for a minute or so and the whole ring gets turned off. This used to work fine for the last 3 years but I've started noticing that the 24VDC "DC ON" indicator is dimming a bit, then dimming a bit more, then not turning on at all. I've measured the voltage output from the PSU and it's fluctuating between 20-40VDC, often dropping out almost all the way and barely reaching 20VDC. What is interesting is that if I leave the rig powered on for a longer period of time (>10-15min) the PSU eventually reaches high enough voltage levels that the indicator lights up and all works as before.
At first I thought the diodes in the rectifier are dead, but now seeing the way it springs back to life after 10-15min I'm not so sure anymore. I'm planning to get the PSU out of the rig chassis this weekend, but I'm not 100% sure what to check for. One possibility is that something inside the PSU simply warms up and then starts working properly? can it be a capacitor somewhere that takes ages to charge? looking at a diagram of an unregulated PSU there's not much inside, a transformer, a rectifier bridge and a cap on the output line to act as a filter. Another thing which I'm not 100% sure about is why it failed in the first place as there might be something in the entire set up that is causing premature failure. Would the AC being turned on / off often and the fact that the servomotor controller and the PSU are on the same line have something to do with it? could it be the zener diode sitting on the output of the PSU?
Any help is much appreciated as usual : )
Cheers,
T.
Cheers,
T.
