blueroomelectronics
I'm just learning C so bear with me.
It's not beautiful and I could use some advice on cleaning up and making the code more efficient. I'm porting it over from a Swordfish BASIC program I wrote recently and I've only just started learning C (two weeks so far). It's written for the 18F46K22 as a tertiary serial port on PORTB0 & 1 using Timers 2 & 4 plus INT0
I'll run it on actual hardware in the next couple of days. I'd appreciate any comments or concerns.
Untested on XC8, the Swordfish version works.
* Author: Blue Bill
* Created on June 13, 2013, 11:10 AM
* 9600baud interrupt driven low CPU overhead full duplex software serial port
* Uses Two timers and INT0 (falling edge IRQ on RX)
* RB.0 = RX, RB.1 = TX in this example
* this example uses Timers 2 & 4 (other timers can be used if desired)
* a 1MHz instuction clock was used for simplicity
#define QBAUD 103 // 4000000 / 4 / 9600 - 1
union both { // QTXSend.byte = char, QTXSend.Shiftbit.B0
char byte;
struct {
unsigned LSB : 1, none : 6, MSB : 1;
} Shiftbit;
} QTXSend;
unsigned char QTXControl = 0; // make = 11 to transmit byte in TXQSend
unsigned char QRXCount = 0; // shift in counter
char QRXin = '\0'; // QRX recieve byte
void InitializeQART(void);
void interrupt ISR(void);
main(void) {
InitializeQART();
INTCONbits.PEIE = 1;
INTCONbits.GIE = 1;
QTXSend.byte = 'a'; // test
QTXControl = 11; // test
while (1) {
void InitializeQART(void) {
TRISBbits.RB0 = 1; // QRX in (INT0\ & RB0)
TRISBbits.RB1 = 0; // QTX out
LATBbits.LB1 = 1; // Space
PR2 = QBAUD; // TMR2 104µS QTX clock
T2CON = 0b00000100; // Timer2 1:1 postscaler, T2 on, 1:1 prescaler
PR4 = QBAUD; // TMR4 104µS QRX clock
T4CON = 0b00000000; // Timer4 1:1 postscaler, T4 off, 1:1 prescaler
INTCON2bits.INTEDG0 = 0; // falling edge detect enabled on RB.0
INTCONbits.INT0IE = 1; // enable INT on falling edge RB.0
PIE1bits.TMR2IE = 1; // enable TMR2 (TX) interrupts
PIE5bits.TMR4IE = 0; // disable TMR4 (RX) interrupts
void interrupt ISR(void) {
// QTX 104µS (9600baud,N,8,1)
// check QTXControl for 0 before putting a byte into QTXSend
// then QTXControl = 11; to send the byte in QTXSend
if (PIR1bits.TMR2IF == 1) { // QTX baud clock every 104µS period
if (QTXControl != 0) { // copy 11 into QTXControl to send char in QTXSend
QTXControl--;
if (QTXControl == 10) { //
LATBbits.LATB1 = 0; // Start bit
} else {
if (QTXSend.Shiftbit.LSB == 0) {
LATBbits.LB1 = 0;
} else {
LATBbits.LB1 = 1;
QTXSend.byte >>= 1;
QTXSend.Shiftbit.MSB = 1; // fill with 1's
PIR1bits.TMR2IF = 0; // QTX done
// QRX Start bit detect (INT0 falling edge)
if (INTCONbits.INT0IF) { // QRX pin went low
if (INTCONbits.INT0IE == 1) { // only process if IE enabled (Start bit)
TMR4 = QBAUD >> 1; // add 0.5 bit to sample clock
T4CONbits.TMR4ON = 1; // start timer 4
INTCONbits.INT0IE = 0; // disable INT on falling edge RB.0
PIE5bits.TMR4IE = 1; // enable TMR4 (RX) interrupts
INTCONbits.INT0IF = 0; // always clear IRQ request
// QRX shift bits from PORTB.0 into QRXin
if (PIR5bits.TMR4IF == 1) {
if (PIE5bits.TMR4IE == 1) {
if (PORTBbits.RB0 == 0) { // shift bit into QRXin
QRXin |= 0x80;
} else {
QRXin &= 0x7F;
if (QRXCount > 7) { // full byte shifted in
T4CONbits.TMR4ON = 0; // Stop timer 4
PIE5bits.TMR4IE = 0; // ignore timer 4 IE
QRXCount = 0; // clear the bit shift counter
INTCONbits.INT0IE = 1; // enable INT on falling edge RB.0 and wait for next Start bit
} else {
QRXin >>= 1; // shift bits in
QRXCount++; // increment bit shift counter and wait
PIE5bits.TMR4IE = 0; // always clear IRQ request
