If it's a dos machine then you could do "copy com1 a:\filename.txt". I can't remember how to terminate the transmission. I think it may be terminated when a ctrl-z is received.
You can see the settings for com1 by doing "MODE COM1" and change it by doing "MODE COM1: baud=9600 parity=N data=8 stop=1" - without the quotes.
Note that this is only good for text files. You couldn't use this method to transfer a terminal program.
One day this may be the only way someone might get an old text file of a floppy.
hi Mike,
I cannot understand why he dosnt use a free copy of GW or QB basic.?
It would give him all the port and disk control he needs.?
He may be trying to get a copy of GW or QB on the machine and only has a dos disk. Unfortunately, the above wont work as it's only good for text files.
That frightens me. Lately I've been noticing that computers don't have floppy drives any more, and I *really* need to get my floppies out of storage and use one of my old machines to try to save as much as I can.
Back to the topic: I thought the OP was asking how to send a file to the PC from the Z80 and cause it to be saved to the a: drive, without any comms software running on the PC. I am aware of no way to do that; there must be some software running on the PC to accept the connection, read the data, and write it out to the disc.
Don't be frightened. Every mainboard still comes with a floppy connector. I regularly build machines (for other people) without floppy drives. I have a drive on the shelf with cable that I plug in and run hanging out the side temporarily for whenever I need a floppy in a machine. When done, unplug, change the BIOS setting back and put the side cover back on. 99% of users do not need a floppy drive, but I do occasionally.That frightens me. Lately I've been noticing that computers don't have floppy drives any more, and I *really* need to get my floppies out of storage and use one of my old machines to try to save as much as I can.
