Analog said:Care to mention what processor? Is this an IBM-360 mainframe by any chance?![]()
ericgibbs said:hi,
This is the device he is referring to:
Code for which microcontroller???
http://www.oopic.com/gp2d12.htm
ericgibbs said:hi,
ericgibbs said:hi engkhlaif.
We now understand which controller, 16F877A , OK.![]()
Which programming language are you using, for example, Assembler, Basic or 'C' ?
engkhlaif said:thanx again for care man
surly the language i used in programming is c language
u know what the purpoe is to read the signal from ibject and then while the sensor sensing the object that is moving toward it , it will display the distance on an lcd
example
if the distance is about 20cm then the sensor read it and then convert from analof to digital then convets it to distance and display it as distance not voltage
i hope that i make the veiw very clear for u man
thanx
ericgibbs said:hi,
I did find this web link:
http://uk.search.yahoo.com/search?ei=utf-8&fr=slv8-&p=GP2D12 PIC C examples.
I Googled for: 'GP2D12 PIC C examples'
EDITED:
This looks helpful.
http://mdubuc.freeshell.org/Common/gp2d12.c
