Usart and VBA (Excel)
aduri
Hello,
with this sw (Mikrobasic) I'm trasmitting 3 values, obtained by pic with an ADC conversion, through serial port.
I receive the values with the sw Yperterminal in this format xxxxx,xxxxx,xxxxx;xxxxx,xxxxx,xxxxx; etc....up to 84 groups of 3.
I'd rather do this with VBA of Excel to obtain a few curves (or VB6).
Can you help me with some examples?
Thank you
Bye
Antonio
program adc3_232
' microcontroller P16F877A
' http://www.mikroe.com/forum/viewtopic.php?t=5878&highlight=datalogger
' Project: adconlcd
' This project is designed to work with PIC 16F877A
' with minor adjustments, it should work with any other PIC MCU
' that has ADC module.
' This code demonstrates how to use library function ADC_read, and library
' procedures and functions for LCD display (4 bit interface)
'  It sends the ADC conversion through USART.
dim t as word
    Text as char[20]
    tword as string[5]
    i as byte
sub procedure end_adc
    lcd_cmd(LCD_CLEAR)
    lcd_out(1,1,"sampling")
    lcd_chr(2,9,"E")
    lcd_chr(2,10,"N")
    lcd_Out(2,11,"D   ")
    '   Usart_Write(",")
            delay_ms(200)
end sub
sub procedure setup
    lcd_cmd(LCD_CLEAR)
    lcd_out(1,1,"Inizializing")
    lcd_chr(2,9,"S")
    lcd_chr(2,10,"T")
    lcd_Out(2,11,"ART")
    '   Usart_Write(",")
            delay_ms(200)
end sub
sub procedure sec1
 t  = ADC_read(0)
    lcd_cmd(LCD_CLEAR)
    Text  = "V1"
    lcd_out(1,1,Text)
        lcd_chr(2,15,"V")
      wordtostr(t,tword)
           Usart_Write_text(tword)
      'lcd_chr(2,9,48+ch)
      'lcd_chr(2,11,".")
      lcd_out(2,3,tword)
      Usart_Write(",")
      delay_ms(100)
end sub
sub procedure sec2
 t  = ADC_read(1)
    lcd_cmd(LCD_CLEAR)
    Text  = "V2"
    lcd_out(1,1,Text)
        lcd_chr(2,15,"V")
      wordtostr(t,tword)
      'lcd_chr(2,9,48+ch)
      'lcd_chr(2,11,".")
      lcd_out(2,3,tword)
      Usart_Write(",")
      delay_ms(100)
end sub
sub procedure sec3
 t  = ADC_read(2)
    lcd_cmd(LCD_CLEAR)
    Text  = "V3"
    lcd_out(1,1,Text)
        lcd_chr(2,15,"V")
      wordtostr(t,tword)
      'lcd_chr(2,9,48+ch)
      'lcd_chr(2,11,".")
      lcd_out(2,3,tword)
      Usart_Write(";")
      delay_ms(100)
end sub
main:
    Usart_Init(9600)
  TRISC=0x00
  PORTB  =2
  TRISB  =0
  intcon =0
  Lcd_init(PORTD)
  lcd_cmd(LCD_CURSOR_OFF)
  lcd_cmd(LCD_CLEAR)
  'Text ="curve tracer"
  lcd_out(1,1,"datalogger")
  Text ="A. Durighello"
  lcd_out(2,1, Text)
  'Setbit(PORTB,1)     'for usb project
  OPTION_REG = $80
  ADCON1     = $82
  TRISA      = $FF
  Delay_ms(200)
  lcd_cmd(LCD_CLEAR)
  Text  = "Samples:"
  lcd_out(2,1,Text)
  setup
  for i = 0 to 83 '(84x3 samples=252)
          sec1
          sec2
          sec3
  next i
'  while true
'          'setup
'          sec1
'          sec2
'          sec3
''          sec4
'    wend
'Usart_Write(";")
end_adc
end.
See the attached excel sheet. It is a simple demo of how to receive serial via VBA. I had to zip it as .xls files aren't allowed.
The example expects the data to contain CrLf (0x0d,0x0a) so something like a GPS receiver would work.
  • UART Example.zip
Thank you for your replay,
but the compressed file attached isn't on excel format.
It is without extension.
Plese send me the correct file.
Bye
Antonio
It worked fine for me. When I clicked the file winrar opened it for me, when I clicked the compressed file Microsoft Exel opened. It displayed a Start/stop button in the spreadsheet.
What extenctions did it show?
Pommie, can you send me the file without decompression?
I have a old office 97.
Bye
Antonio
I have saved it as a 97 excel file and changed the extension to .txt as .xls isn't allowed. You will need to save it and rename it. Let me know if it works.
  • UART Example97.txt
