do u use all the o/ps of LPT to control the device, if u have 2 o/p pins free , then i think this soln can be applied.salem01 said:i have some projects work with LPT port but the problem when the PC starting in boot the hole pins in the parallel port is ON and that means the devices will be also ON until the windows start ,
i think to put an IC or something like that to keep devices OFF until windows start after that my program will connect with my circuit by DLL file which means a driver for the IC ..... :cry:
now i think there's one solution for that IC or some small circuit to keep devices off until connected by DLL file which doesnt work until the program start and that all what i exactly want ......
use 16F628A , for rs232 , good ampount of information available in netsalem01 said:please tell me how can i use PIC and which nimber i can buy
salem01 said:but how can i connect that PIC to serial port wich pins i have to choose
and do you use it before ? :?: :!:
how many devises can I switch ON or OFF through computer ? :?: :!:
which language you used VB or C++ or other ? :?: :!:
pls look at the link i providedsalem01 said:but how can i connect that PIC to serial port wich pins i have to choose
depends on the nof I/O of the PIChow many devises can I switch ON or OFF through computer ? :?: :!:
u can use bothwhich language you used VB or C++ or other ? :?: :!:
