Hello dears , first of all I'd like to thank you for this great forum![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I want to disscuss this project I'm doing so I don't screw everything due to my bad experience ...
This project is about controlling some LED's using a software via USB cable so I can control each LED indivisually ...
and that's the circuit :
well I got 2 problems with this project
1- in the circuit i'm required to use a PN61729 microcontroller , but I'm not able to get 1 so (and as I was told) I used a PIC16F84A microcontroller and I burned the .HEX file on it which is provided with the project's files, So the question is how do I connect the circuit with the new IC , I've confirmed some pins , and here they are :
(the position of each pin from PN61729 to PIC16F84A microcontroller)
RESET : 1 to 1
OSC1 : 9 to 15
OSC2 : 10 to 16
LED0 : 23 to 10
LED1 : 24 to 11
LED2 : 25 to 12
LED3 : 26 to 13
VCC : 7 to 14
GND : 8 to 5
D- : 2 to ???
D+ : 4 to ???
and to the jumper :
MOSI :17 to ???
MISO :18 to ???
SCK :19 to ???
2- the software of the project is a source code (not compiled) so I need to compile it by myself , but whenever I try I get the error "fatal error C1083: Cannot open include file: 'usb.h': No such file or directory
Error executing cl.exe"![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
so I'll not be able to compile it till I get that file and I don't know how![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I know that I'm being such a "troublesome" with bad experience ... but I need to do this , and I really want to learn how to get this circuit to work ...
Project's Source : Die Schatenseite: USB-LED-Fader
Files Link : **broken link removed**
RESET : 1 to 1
OSC1 : 9 to 15
OSC2 : 10 to 16
LED0 : 23 to 10
LED1 : 24 to 11
LED2 : 25 to 12
LED3 : 26 to 13
VCC : 7 to 14
GND : 8 to 5
D- : 2 to ???
D+ : 4 to ???
and to the jumper :
MOSI :17 to ???
MISO :18 to ???
SCK :19 to ???
