upand_at_them
Active Member
I have a problem with interfacing the DTR signal line of a USB-serial bridge (CP2102) to a microcontroller dev board. (Both are 3.3V.)
I'm using the bridge to flash new firmware to the uC. I manually jumper the uC's reset pin and one pin used to signal bootload mode. Works perfectly fine this way. But...
When I try to automate it, by using the USB-serial bridge DTR and RTS lines to control those uC pins (via a Python script), things do not work. Specifically, my problem is with the DTR line that goes to the "bootload" input pin on the uC. It shows a ton of noise when held either high or low.
With the uC disconnected, no noise. But with it connected there is too much noise to have a reliable trigger signal.
I have solved the problem by using a transistor in between the DTR line and the "bootload" pin. (And then inverting the signal in the Python script.)
But here's my question (finally): Why do I need to do this? Why am I having trouble connecting the DTR line directly to the uC "bootload" input pin? They both operate at 3.3V levels. And I have tried all manner of pullups and pulldowns, to no avail. And is there another solution such that I don't have to invert the DTR signal (without using a buffer chip)?
