USB to TTL help
woody
I have an old GPS unit from an OnStar system and have a couple of diffrent schmatics to hook it up to a computer. My problem is they all call for the RS232 shifter, namely the one from from sparkfun. Any ideas on how to convert that idea to a USB type of shifter as well as being able to use the ground and 5 volt side to power the unit? Any help would be appreciated.
3v0 said:
Are you taking about the SparkFun USB Bitwacker? If so are you not wanting to use it because of current limitations.
How much current does the OnStar system draw ?
Not the SparkFun USB Bitwacker but rather like the RS232 Shifter, just with an USB plug, not the RS232 connector. It will need 5vdc. Here is a link to what I am trying to achieve. CLICK HERE
It looks like those programs are using COM1. Unless you can find a USB program or write one that can interface to Google, I would stick with RS232.
No Porgramming Solution
On the PC make the USB look like a COM port. Use a USB>RS232 converter to connect to RS232 shifter which connects to OnStar.
PC side
Microchip has a PC device driver that uses USB but creates a virtual COM port. It will let you use a PC program written for RS232 with a physical USB connection. The UBW instructions help you find and install it.
OnStar side
Get a USB to RS232 converter. If it does not provide the +5 you can open the cable and get it as described in the link you provided.
Power for the module is obtained from a PC USB port. Take a scavenged USB cable and connect the red wire to both the module's +5V pin and the VCC pin of the RS232 Shifter [see diagram above]. The black USB wire is connected to the GND pin of the module and the GND pin of the RS232 Shifter. Now attach the RS232 Shifter to the PC's DB-9 serial port and connect the shifter's RX pin to pin 8 of the module and the shifter's Tx pin to the module's pin 9. Finally, plug the GPS antenna into the module.
Should work and there in no programming.
Most any USB>RS232 converter should work because only the RX and TX signals are used.
