So, as the title suggests, I like to use my aviation headset with my Android (or other type) phone. Not only to listening, but also talk on the phone.
But I'm having some issues I like to sort out before I go serious with this.
First, what I have and have done so far:
The aviation headset (hereon AHS) is a new Quiet Technologies Halo with a audio input jack. On the PCB of the volume control box, for each channel and in series from the audio jack to the earphone traces, there are one smd 100ohm resistor and a 1210 ceramic capacitor of unknown value. No possibility to switch the 3-pol audio jack to a 4-pol phone jack, so I plan to use the same values of these components for my own connection point (between headset and volume box). I'll find a way to figure out the cap value.
For the electret mic on the AHS:
From David Clark:
"Electrical Specifications–Microphone Model M-7A (P/N 09168P-33)
DC supply voltage and source resistance: 8 to 16 volts, 220 to 2200 ohms-not polarity sensitive. "
But electret mics can often be biased by lower voltages than that
Android headset specifications **broken link removed**
I have an old Android headset where I opened up the little mic-n-button-box and removed the mic from the small PCB, attached two wires at its place and connected them to the AHS (not actually on the AHS, but in a genav-to-helicopter adapter). The 2.9V from my phone seams to be sufficient to bias the mic. I measured the dB with an app on the phone and compared to an unmodified headset (not calibrated scientific values, but about the same). Also made some phone calls with good sound quality of my voice.
Now to my issues:
1) Bias isolation
I like to be able to talk in the phone while either connected to my aircraft or not, and be able to disconnect/reconnect to my aircraft while doing so. I need some automatic isolation between the com-radio and android bias.
Would a cap in parallel with a diode between mic high on AHS and the positive mic wire from the Android be sufficient?
When connected to aircraft the signal pass through the cap while DC is blocked.
When disconnected bias supplied through the diode (hopefully the 0.7v drop won't cause issues).
2 & 3) Mic Low VS GND and Bias polarity
So, on the AHS, the mic has two connections, Mic High and Mic Low. Mic Low is not connected to headphone GND as it is on the android counterpart. So if I connect the AHS mic to the android headset as described above, Mic Low will be short-circuit to GND when connecting android headphone.
What problems might this lead to?
I found an interesting wiring diagram:
Here one can see that headphones are connected to GND, and mics to "Point A" i.e. "Intercom Central Ground Point". Not the same?
But looking at the David Clark Specifications again: "...not polarity sensitive."
This imply the polarity of the mic bias might be switched, Mic Low get the 8-16V and Mic High are grounded!
This might complicate things.
Any ideas?
Any circuit related suggestions are welcome.
But please avoid "go spend money on this or that instead" kind of suggestions, I know there are commercial solutions available, but whats fun with that?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And if there are commercial products available, someone need to know how to build one...
BR
/H
Edit:
Realized the second issue was actually two.
From David Clark:
Now to my issues:
1) Bias isolation
Any ideas?
BR
/H
Edit:
