using AVR GPIO PINs to send and receive DATA
firstoption
Please i need your support on how to put these codes together.I am using Attiny24A to read Temperature from a temperature sensor and i want to send these Temperature value to the Computer through Attiny4313.I have two GPIO Pins from Attiny24A connected to two GPIO Pins of Attiny4313.
My question is that is it possiple to use These GPIO Pins to send and receive data.The program below was written to Attiny24A
DDRB|= (1<<PORTB1); //Attiny24A(PB1) as Output Pin(to send DATA)
DDRA|= (1<<PORTA7); //Attiny24A(PA7)as Output Pin(for clocking the DATA)
void ClearClock()
 PORTA &= ~(1 << PA7);  // Set PB1 LOW
void SetClock()
 PORTA |= (1 << PA7);  // Set PB1 HIGH
void ToggleClock()
 _delay_us(50);
 SetClock();
 _delay_us(50);
 ClearClock();
 clockcount++;
void SetData()
 PORTB |= (1 << PB1);  // Set PB1 HIGH
void ClearData()
 PORTB &= ~(1 << PB1);  // Set PB1 LOW
void Send_ObjTemp_8bit(unsigned int data10)
 int i=7;
 do
 if (((data10 & (1<<i))>>i) == 1)
 SetData();
 else
 ClearData();
 ToggleClock();
 i=i-1;
 while (i >= 0);
int  main( void )
 DDRB|= (1<<PORTB1); //µC Data_Out
 DDRA|= (1<<PORTA7); //µC Clock_In
  sei();
  setup();
  while(1)
 Send_ObjTemp_8bit(Tobj);
The program below was written to Attiny4313
DDRB &= ~(1 << PB1);//Attiny4313(PB1)as Input Pin(to receive the temperature value from attiny24A)
int  main( void )
  unsigned int TempValue;
  while(1)
  TempValue=PINB1;
  USART_Transmit( TempValue) //this function sends the temperature value to the Computer.
